engine tune question
XxVASSAGOxX
Gone - bye bye.
Hickory N.C.
ok so i got the lsn flush, and the hsn 5 turns out from closed this is suposed to be factory setting, it instantly floods like this, how should i tune this TRX3.3 for 65ish degree weather? it has awsome compression.. thanks for info
ok i had the lsn out to far, i had it flush with the thing, but it accualy means flush with the inner ring, so i was off about 2.5 turns out on it ?, ok so i turned it in 1 turn on hsn and flush with rim on lsn sound right?
Yeah, I believe they do in fact mean flush with the inner ring, not the outer. It gets confusing, so I figured the pic would help some. Good luck. :)
yes and just to clear somthing up, i miss read what someone told me, they didnt say 5 out was factory they recomended 5 out cuz it sounded like i was way lean, i miss read what he said, its to late to run it now, with *** ass nabiours but tomorrow ill find out if this works, then its time to adjust the clutch
