engine temp. help please
raceman
hey guys is it good for ur engine to run cooler than normal operating temps because yesterday was a pretty cold day like 55 degrees and my engine was probably running in the 220-230 degree range and i thought it would be better for it but i dont want to shorten my engine life by runnin it too cold so any of you got any suggestions??:dumb:
:redbuggy: :redbuggy: :redbuggy: :redbuggy:
I myself thought that by leaning it out will give you higher temps.but after reading a post from anther part of this forum I’m not sure if it is a good thing to do when temps ar that low outside. I would also like some input on this.
Cooler weather outside makes for more dense air. More dense air requires more fuel to keep the air/fuel mix correct. So, you would want to richen things up a smidge.
As for the outside air being cooler and causing lower running temps, that is possible. You will get better performance from the cooling head with cooler outside air. The engine will in turn perform a little better due to the fact that the engine works on a combustion cycle that uses exhaust gas and the expansion of said gas to move the piston. The bigger the temperature split between the intake air and the combustion temp, the more rapid the expansion and the more energy created within the chamber. This in turn means more power from the engine.
So...yes, the engine should run cooler on cooler days due to better cooling from the engine's cooling head. Yes, you need to adjust your needles to get the same performance. No, the cooler temps shouldn't impact engine life, unless they are way too cool.
Hope this helps.
See learn something new today. That’s why when your running on a humid day at a rich setting and the next day a cold front comes in with dry air the engine is faster.
