If you are going to be in the world of nitro you are going to have to learn how to tune. I was scared of it at first but the article I read in my RC Car Action really demystified tuning a nitro engine. The biggest thing you need is patients. Once you find the sweet spot it will be worth it.
The following chunk if info was posted by NA in a previous post. I liked the information so much that I made a Word document out of it, printed it out and put it in my field box. So when I am having problems I will take a break from it, read this, and go back to the problem at hand.
If there is one thing I have learned it is that every engine will start. There are only four things that make a nitro engine run:
Fuel
Air
Compression
Combustion
All of these things must be in effect to start. So lets check them out.
Fuel: Can you see the fuel going from the line into the carb?
Air: Is the carb opening, is the airfilter clean?
Compression: Is there compression? If it is a new engine you should be ok. You can check it by manually turning the flywheel with your thumb, it should be almost impossible to do.
Combustion: Have you checked the
glow plug on the igniter while it is out of the car, and made sure it glows bright?
If all these things check out than it can only be one thing: You need to adjust the mixture of the fuel and air.
