Engine leak
Rc legend
Hi everyone,i have a problem with my car,when i pull the starter,fuel dispells from the cylinder head?like iv got a leak but piston & liner seem tight,also seems low compression?abviously because there is a leak somewhere,can someone help me?
as I'm stupped at the mo?
welcome.
first up, one thread is enough, someone will come along soon enough to help.
now to your issue. there are 4 screws down inside the cooling head on the engine. those need to be tight. but they also need to be tightened down a certain way. so lets start with taking those off, and checking the mating surfaces between the cooling head and the crank case. get some pics and post them here so we can see what it looks like.
be careful as there may be some very thin metal shims in place between the head and crank case.
then when you put it back together, run the 4 screws just finger tight, then turn them in a X pattern a 1/2 a little at a time until they are all tight. you want to tighten them down evenly.
with the head off when u pull the starter,a little fuel
dispells of the top,is this normal??
yes. the engine is basically just an air pump. the sleeve looks a little mared up, but not terrible. i would put it back together with the procedure i listed, and see what happens.
also be sure to use blue locktight on the head screws.
it is kinda rough, but its worth a try to see if you can get it sealed up. if not, you will have to get a new sleeve and piston.
if it had a shim on it, it needs to go back on.
I myself wouldn't bother trying to fix it. Not knowing the engine type (rotary/slide carb, standard/pilot shaft), it appears to be a side exhaust. The OS18 is a solid little engine that would be a good replacement.
3 types at the bottom of this page:
http://www.towerhobbies.com/products/os_engines/osmg2100m.html
