Joe From East End Machining in cooperation with RCNitroTalk is giving away one of his Dual Triangulation Skid Plates for the AX10. To one of our supporting members.
It's real simple, all you have to do is post once in this thread with a picture of your crawler, scx10, or even x-trail to be entered to win. Post only once or you will be disqualified. We will pick a winner next Sunday April 19th
Good Luck!
Good Luck!
Delrin Dual Triangulation Skid Plate for Axial AX-10 Rock Crawlers
This skidplate is designed to work with the stock axial chassis and suspension components. It is a direct bolt in replacement for the stock Axial skid plate (transmission mounting plate).
EEM’s AX10 Skidplate has been computer designed to lessen and correct the “Rear Steer” effect commonly seen in the AX10. Rear Steer occurs when the rear axle articulates at an angle instead of straight up and down. This is often caused when the crawler is in a bind and power is still being applied by the motor to clear the obstacle. Rear steer puts extreme stress on the suspension components and in extreme situations can cause damage to suspension components such as torn out links.
East End Machining’s skid plate is designed to minimize and in many cases eliminate the Rear Steer effect as well as keeping chassis torque twist minimized.
Since it is CNC machined from Delrin it can slide over rocks and other obstacles very easily. Another nice feature is that our design allows the skidplate to hang slightly below the bottom of the stock chassis plates. This helps to keep the aluminum chassis plates off the rocks thus reducing the drag and scrape of metal seen with the stock plates. For Carbon fiber chassis plates this is a must have solution.
This skidplate will provide the user with a competitive edge over other’s running much more expensive aftermarket chassis setups. In comparison it is a very inexpensive yet totally effective option.
Don't get left behind in a bind with the stock Axial skidplate!
Item Includes: 1 Delrin Dual Triangulation Skid Plate and all necessary low profile mounting hardware.
East End Machining
