chaos2767
I have had this motor now for a few weeks and do have to say that it is a great upgrade from the 2.5. The motor is very easy to tune and does hold a tune well. I swapped to the pull start which the standard Traxxas 2.5/3.3 pul start will work on this motor, just need to pull, clean and lube the one way bearing from the ez start. Anyone who was contemplating this motor, I would recommend it. Everything swaps directly over such as the flywheel, clutch and clutch bell, their are no mods necessary to run this motor on the Maxx. The reason I switched to a pull start was because the ez start had a hard time turning this motor over but would do it, it just drains the battery in the wand really quick. With the pull start, I can get it to turn over within 5 pulls.
