Dx2s
buggybuster
RCTalk Qualifier
Burlington NC
Purchased a new spectrum dx2s for my savage, that thing has been nothing but trouble. Has anyone else had problems wit it. Mines glitches at bout 20 yds. and the telemetry
Dont evn work, horizon sent a new reciever and I'm having the same problem. Any suggestions or did I jus make a bad choice wit the spectrum period.
Are you runnig new batteries in it? Also are you running rechargerables or alkalines? Where is you little antenna run as well? I have a 3S and 3R and have never had a problem except tryibf cheepo batteries or lower voltage rechargables.HtH.
I'm using regular duracells now, wit my antenna justraight up, I also have a buggy binded to controller and it run jus fine.
I had a problem with my dx3c glitching and cutting out at about 30 ft and found my antenna wire off rx broken about 1/2 inch off board. Soldered it back together and bandaged it with heat shrink and fixed it. But it still doesn't have the range my 27mhz radio did.
