mcvickj, just before your engine died in your Savage, did you notice how the power would noticeably increase as the tank got past halfway? That was due to it leaning out excessively which ultimately destroyed your engine.
I agree with what you say about most vehicles leaning out as the fuel level drops, it's bound to happen as the pressure slightly decreases in the tank because of the drop in the fuel level, but it is mostly negligible. In the Savage, however, this problem is made much worse because of three things, the stepped shape of the tank, the poorly sized baffles and the ridiculous positioning of the fuel outlet at the front of the tank. With the outlet being at the front it means that when the fuel drops below a certain level every time you accelerate the fuel is drawn away from the outlet leaving you with just air in the pipe!
Renegade88, yeah, that's the way to connect it, just make sure that the line from the header tank to the carb is connected to the clunk, (the flexible pipe with a weight on the end inside the tank) and the pipe from the stock tank goes to the uppermost nipple (originaly a breather/filler/pressure connection.)
bmoc2008, I live in the UK and a set of Joes and rims costs around £80, that's around $130 I think.
The header tank is filled initially by swopping the two pipes over and pumping fuel in from the main tank with the primer, then, when it's about 2/3 full put the lines back to their original places, top up the main tank again and away you go. If you keep re-filling as usual, when the main tank empties, then you don't need to touch the header tank again.
Phew . . . I can stop for breath now! :write:
Kev
