on this jato its the second losi carb I have done ,the first being a 3.3 maxx .on the maxx I had to lightly sand the neck of the carb to get it to fit then a light smear of rtv and I was good to go as it comes with a ball connector and it fits the trx linkages with no problems. the jato on the other hand on didn't have to sand anything the losi carb slid right in and used all the existing hardware and linkages ,did take a bit of fiddling around to get wot but nothing too dramatic. the only traxxas truck its can be a bit tricky to use a losi carb is a revo/slayer due to the mixer arm being the way it is but you can just shim it with washers and Loctite it when you have it set.
what I have found by using this carb is it makes the 3.3 a better engine ,it holds a tune and idles like a champ all day long plus the big side is more power mainly at the top end but there is a small increase in the bottom that combined with a ths exhaust ,I also ditched the botton type air filter for a t maxx 2 stage one ,its a tight fit under te roll bar but its worth the hassle imho.
for initial tune I have found the needle setting are somewhere between the stock losi and stock trx ,once you find the sweet spot you never have to touch them again.
