dual engine
nickel417
I am going to be building a custom t-maxx chassis and i want it to be dual engine? How do i link up the two engines?
most of the time you see them hooked to one trans.. one on each side of the spur so theres not much complicated there and as for fuel tank just run two tanks one for each engine....the tricky part is is hooking the linkage up right..the best way is to go with two slidecarbs and run a staight peice of linkage with two ball connectors on each end and hook the two carbs up making sure that when one carb is closes other is and so on, making sure they are both equal.. and then from there you can hook another linkage to your bell crank ...now granted that was just a basic run through..best bet is to just get a bunch of pics and copy what they have...
also check this site out youll prlly like it i remember this guy from like 4 years ago he was one of the first to do this...
http://www.projecttwin.com/ProjectTwin.cfm
Lessen had a nice twin maxx rig.....PM him and see what he has to say about it.......OR search the forum....
where can i find some good steel gears? Where can i find a really strong clutch?
