OMG what the heck!! I switched to the 18 tooth gear and to do so had to pull the engine out. Now back in it idles high and wont shift!!
I have done everthing to adjust the idle with no luck. to the point when you hit the brakes it kills it. I have re-adjusted and fixed that issue but the iddle is still high.. I'm thinking the smaller tooth clutch bell was enough speed right now!! I have also check fuel lines, no breaks and good connections..
Thanks,
Craig
Thanks,
Craig
