Hi all. My maxx is playing up big time now. It will only idle at half throttle. Which means i have not breaks because the minute i apply the breaks it stalls because it less then half throttle. I have tried many many many setting on the carb but nothing works i have to trim it to halfway throttle on the remote for it to start. Its also very difficult to start and its blown glow plugs like its some kind of hobby the engine has. Its the standard trx 25 engine. Never really had it running well at all. I fitted an over sized head and this did improve it a lot. But its still never been perfect. It blew 2 plugs yesterday on the same tank of fuel. The head bolts are tight the plug is tight the carb setting are flush on the lsn and 3 turns out on hsn. Have tried opening the lsn right up see if that cured its idleing problems but nothing. changed all fuel lines and air filters. The engine does have compression and on stripping it down a little i noticed small fragments chipping off the bottom of the piston. I cleaned all these because they would cause it to lock sometimes. But the surface and the fit between the sleeve and piston seem perfect no leaks or or scores on the sleave or anything. I still have the original trx 15 engine which to be fair seemed far more reliable and only lacked in torq the speed itself was very simlar really. I have probably not had more than 2 gallons of fuel through it and even thats probably exagurated as i can only actually find 3 half gallon containers of tornado 25% in the garage and thats the only fuel i use. Hope someone can help.
