i have my 3.3 motor on my revo for about 2 years now i think i ran about 5 gallons on it...when i try to fire it up it runs but when i try to give it throttle it bogs and dies..i redid the HS/LS to factory and open up the motor if theres any binding or anything like that..the piston seems to go smooth and i can feel air sucking on the carb when i turn the piston so that means i still have good seal on the piston and sleeve..no leaks or anything..also lots of blue smoke when i fire it up..i did lower the high speed and still fires up but with a little smoke this time but when i open the throttle it bogs and dies aswell..i lower the LS just a bit but still..plugs are good using MC#8 been running on that for a while..my tank Oring broke so i just put silicon and let it dry and test the air pressure by blowing in it under water and no air leaks..my starter is full batts..and I'm running on 20%
do i need a new engine?
thanks:bow:
thanks:bow:
