Link does not compare to the LE which is what he is looking for.
Here is what the LE features so you can wade throught the list on SM's link and this list.
Product Information
Features:
* Adjustable 3 speed transmission with heavy-duty metal internal
* Polished aluminium dual chamber tuned pipe
* Dual stainless steel drilled disc brakes
* Chrome 6 spoke wheels
* Dirt Bonz tyres (with inner foam)
* Cam type servo saver
* Optional gearing (15T, 19T, 47T, 49T gears included)
* 4-gear differentials (front and rear)
* Pre-painted trimmed GT-1 truck body in all-new colours with Savage 25 decals applied
* Rear tie-rod washers
* Nitro Star S-25 engine (ABC) with slide carburettor
* Purple anodized, billet aluminium heat sink engine head
* Roto Start System installed!
* Aluminium high flow tube rear exhaust header
* Stiff black shock springs
* Rear pick-up 160cc fuel tank with no primer
* Three-shoe clutch
* Revised wheel hex hubs
* Giant 1/8th scale (16.8" x 21")
* Factory assembled
* Full-time shaft driven four wheel drive
* Complete set of rubber sealed ball bearings
* TF-4 radio system with high torque steering servo
* Cast aluminium heavy-duty engine mount
* Heavy-duty drive train and suspension optimized for big-block engines
* Hardened metal differential gears
* Adjustable slipper clutch
* Adjustable disc brake
* Wide-track suspension (nearly 17 inches wide!)
* Stainless steel inboard hinge pins with anodized aluminium braces
* 8 long stroke oil-filled coil over shock absorbers
* Rigid aluminium TVP chassis (Twin Vertical Plates)
* Enclosed radio box for protection of electronics
* Front and rear skid plate bumpers
* Adjustable body posts (with extra mount for SUV bodies)
