D3MON
- Thread starter
- #41
updates after printing and some revisions!!
believe i got my adjustable chassis hammered out.
printed and fitted lower chassis adjustment:
underside:
Upper adjustment:
Printed:
this allows for adjustment from 98mm through 108mm in intervals of 2mm, with the slotted holes on the bottom of the chassis for the adjustment there.
so far this seems to work really well and easy to adjust. will make revisions if i dont like how it wears, or operates later.
NEXT, is the battery hold down, which i am still on the struggle-bus with, with the size of the battery I'm trying to use.
the holes from the bottom with the posts make the entire chassis wider than i want, trying to come up with ideas for a very low profile holder that is secure and doesn't protrude down or up, though i am starting to think its just not possible.
i do have an idea, but it does require a battery tray on top of the chassis as to not have anything hanging down.
rubber band/top side hold down idea:
(also seen in picture above printed and fitted.)
the one side as seen below with the hinge will have a small rubber band on a ball end anchored to the right rear upper chassis brace/RX post.
fitted:
if this works how i want, eventually i am going to design in multiple widths for different battery sizes, which the front battery holder also opens up to be able to be adjustable, or have different sizes to be able to accommodate.
if the rubber band side does not prove to work well, i am going to repeat what the other side does so it will just pivot on one screw. current line of thinking for not doing that now is i dont have a shoulder screw that small/correct dimensions, and it will eventually get floppy/worn out.
As you can see in the underside pics showing the front chassis (god awful looking because of floating on supports)
i still haven't decided how i am going to keep a similar profile above to allow clearance of the servo horn, while moving it vertically up 1.25mm. i am sure that 3d printed PLA has enough flex that it wouldn't be a problem, but there are some future plans with materials that wont.
anyways that is all the progress so far! going to try drawing up and printing some drift tires here soon (thinking TPU 85?, or might just do PLA+), and might have access to a gyro that will fit on the chassis to give it its first test run.
thanks for reading another wall of text! but at least pictures this time.
underside:
Upper adjustment:
Printed:
fitted:
