CVDS for nitro sport
raceman
hey guys i recently just got some cvds from a friend for a nitro sport. I am having a problem with them. do any of you have a problem were the cvd connects to the shaft that the wheel goes on mine the pin that holds them together keeps falling out (luckily i could find it each time) what should i do to kep it to stay in the hole it goes in:ponder:
if I'm not mistaken, there should be a set screw to hold that pin ?
if not I've seen heat shrink tubing put over the shaft and shrunk to prevent the pin come comingout
slothy is correct. There should be a grub screw (also called a set screw) that holds that pin in place.
