CVD for the new tmaxx 3.3?
I am not all that familiar wth the 3.3 maxx, but I have been running cvds on my maxx for many years with no trouble at all. I would highly recommend them.
As I've been researching for my new 3.3, I think the reason Your LHS told you this is because the new 3.3 (4908 version) has a more "beefy" drive train than the older versions, which tended to have problems(?) in that area. In all my searching, it seems unless you do a serious motor upgrade, the stock should handle things just fine provided you're letting the slipper do at least a fraction of it's job.
My plan, as with everything with my new 3.3, is to use it till it breakes. Then it's time to upgrade. :)
Oh, and what does it do? I think the main "upgrade" to CVD's is that they are steel or aluminum drive shafts... the stock shafts are plastic. (Self explanitory.)
cvds
i upgraded to a 3.3 on my t-maxx and went through four or five sets of stock drives went cvds not a problem since had a few good wrecks and jumps not a problem!!!!!!
then new (forward only) t maxx 3.3 have much beefier center axles. the plasctic u-jointa are bigger and the transmission outdrive are a bigger diameter. the early 3.3 maxx has smaller ones.
i found this out after trying to to use a longer new 3.3. chassis on my early maxx 3.3 it works fine but the newer extended axles are not compatible with my trans.
so its either a revo trany(revo tranny has the larger outdrives) or possibly just the revo outdrive shaft installed into my 3.3. chassis.
or just a set of extend aftermarket ones.
thats weird your hobbie shop doesn't try to offer you a aftermarket part. my shop is kinda like that and it sucks. i went in yesterday and asked for a cx2 part and the guy say"we really dont promote upgrading them becuase they are just a trainer"
wtf?
was it the center axles you went through?
