- North Idaho
- Crawling
Young kids…the ultimate test of durability
I've had lots of cars & trucks, boats & drones too I guess, over the years but been away from it for awhile. For whatever reason the whole Rock Crawler world has me super interested all of a sudden. I bought the TRX4 a few weeks ago and almost immediately wished I had waited and done more research first. I'll never do any competitions or anything, but I'd like a pretty capable crawler, and now I'm seeing ones with animated drivers which I think is really cool. Can anyone point me in the direction of researching that? I have been searching for days, don't want to be that guy that gets the comments "Use the search bar", but maybe I'm not searching the right terms or something. Once I get started down the right Rabbit Hole I think I'll be fine, but any help would be appreciated!
Oh, and I'm sorry if I posted this in a stupid spot. Thank you!
I stand corrected, your TRX4 looks to be very capable! I did buy the High Trail F-150, and I should have at least not gone with the High Trail if I wanted to crawl with it I guess. My "wants" also seem to change week to week, so I may even contradict myself from time to time. At this point, I think I'll put as little money as possible into the TRX to make it a little more crawl-friendly; maybe lighter shock oil, lighter springs, a little weight... Then buy more of a dedicated crawler later. First thing I need to decide is scale; probably 1/10, but the smaller ones are pretty fun with less investment. I'm also going to look in a minute to see if you've listed your upgrades to the TRX, and check out that Vanquish, that's a brand that keeps coming up. Thanks for all the great information!TRX4 not capable, you jest? It won't be a competition rig, but it's not meant to be.
This is the a very difficult climb. This doesn't make the turn, but I might be able to tune my foams and make it happen.
Granted this is far from stock but I don't know of a scale truck (maybe, the Vanquish?) that can do this without mods. The amount of scaleness you want and the amount of performance you want is up to you. They do work against each other though.
So you can buy a VS-VRD and change the body to something more scale, but it would degrade the performance.
What doesn't it do that you would like it to?
Welcome!!!
Nice collection
Lots of people here with knowledge to point you in the right direction.
To be honest, most crawlers out the box will need motors, servos, esc, and wheels and tires. Weight distribution is a must whether the rig is light or heavy. Front 60/40 back. Is the recommended wt. difference. Just be close.
But seeing that collection it won’t take you long and you’ll be winning right of
Winning rig of the month. Supposed to say.Welcome!!!
Nice collection
But seeing that collection it won’t take you long and you’ll be winning right of the month.![]()
Thank you Jerold, LOTs of great info. Quick question about my TRX, I just replaced the steering servo with an Injora because very often when I turn either way then let go of the wheel, the wheels would only return about halfway back to the straight forward position. So I replaced the servo and it still does the same thing. Any idea what would cause that? Doesn't seem to be anything physically binding, although I could look at that better to be certain. I also added all the lights, so I thought maybe I'm trying to pull too many amps or something, but it does it without the body on, so the only lights left at this point are the rock lights. I could try it without them too, but either way I think I'm going to look into the BEC route you gave me some links to above, thank you again. That would give me more weight up front anyway.Don't beat yourself up for getting what you like. The High-Trail is still very capable and looks way cool too.
If you want to lower the CG for $0, crank you springs all the way up (least pre-load) and the truck will sit as low as possislbe. If you still don't have enough droop you could try short springs or no springs.
Verify this, but I think the difference is longer shocks/springs, bigger tires (2.2"), longer arms, and possibly the servo mount?
If that is correct, then you could swap to the shorter shocks/springs and the 2.2 wheels to 1.9, it would pretty close to the standard version. You would still have longer links, which I think would only make the wheel base longer? You could keep the 2.2 wheels work with shorter shocks.
I've changed all kinds of stuff. Now that I look at it I could have gotten a few extra stock rigs for the same $$. I don't have a build log on the TRX4, but maybe I need to make one. . I did this before I found the forums. This is what I can cobble together.
Brass it's like 8 lbs!
Brass Diff Cover https://a.co/d/37b50TKINJORA RC Internal Brass https://a.co/d/8BHxilVBrass Knuckle & Hub Carrier & Portal Knuckle Cover https://a.co/d/4RuDnIJ (I think this is the kit, but just buy the good stuff it was a PITA)
Electronics
ProTek RC 1KTBL Servo https://www.amainhobbies.com/protek...s-waterproof-crawler-servo-ptk-1ktbl/p1331854Hobbywing QuicRun Fusion Pro https://www.amainhobbies.com/hobbyw...-esc-motor-system-2300kv-hwa30120402/p1422717I have also ran a Hobbywing QuicRun Waterproof 1080 G2 Brushed Crawling ESC with a Holmes Hobbies TrailMaster Sport 550 Brushed Motor (21T) The HW Fusion is amazing, but this great combo and less expensive than the fusion.Castle Creations BEC 2.0 https://www.amainhobbies.com/castle...ltage-regulator-15-amp-cse010-0153-00/p575484The BEC wiring is here. It's a bit complex.Radiolink RC6GS V2 https://a.co/d/fT9EH4w.I chose that because it has a 3-way toggle for the lockers . . . that mostly works right. Otherwise I would have gone with Flysky FS-GT5 https://a.co/d/bSqMWsk
Wheels & Tires
INJORA 4PCS 1.9 Inch Metal Wheel Rim Beadlock https://a.co/d/f1OyKlSINJORA Brass Internal Beadlock Ring https://a.co/d/4vFcVkvI've run both JConcepts Ruptures Green & Pro-Line Hyrax G8. Both perform well for me and my terrainPro-Line 1.9" XL Dual Stage Foam https://www.amainhobbies.com/prolin...ck-crawling-foam-inserts-2-pro6174-00/p537245They are a bit too soft for the weight. Looking at upgrading.
Chassis/ body Mods
Vanquish Products VS4-10 Bumper set https://www.amainhobbies.com/vanquish-products-vs410-pro-tube-bumper-set-vps10122/p1007682I've trimmed the body in some places. (Free)Rock slider lift. (spacer and longer screws). (Almost Free)Lowered the body as much as possible. (Free)Relaxed the springs as much as possible. I might try pulling the rear springs completely too. (Free)I use forward battery mount (below) that helps to get the weight forwards.(Free)
Battery
Unless you are hammering the throttle, the Fusion slowly sips electrons, so you can use a tiny light weight battery. They are less expensive too.The current battery is OVONIC 3s Lipo Battery 2200mAh https://a.co/d/5sQUjqM (~45mins)Although I picked up TATTU 850mAh 11.1V 75C 3S LiPo https://a.co/d/iirMYhM for a SCX10 I purchased. These should work as well. (~30 mins with Castle Slate)I have also used these with the TRX (>1hr with Fusion, 30-40 min with brushed motor)ProTek RC 3S Low IR Si-Graphene + HV Shorty LiPo https://www.amainhobbies.com/protek...po-battery-11.4v-4800mah-ptk-5116-22/p1370771gensacearespammers G-Tech Smart 3S LiHV Battery 4300mAh https://www.amainhobbies.com/gens-a...tery-60c-11.4v-4300mah-gea433s60x6gt/p1502570
All in all
The servo and BEC are cool, but overkill.
There are a ton of good wheels out there.
Foams and tires make a huge difference for climbing.
Best of luck with your build, it's going to be great!
Replace tge servo saver. Kimbrough makes a great one.Thank you Jerold, LOTs of great info. Quick question about my TRX, I just replaced the steering servo with an Injora because very often when I turn either way then let go of the wheel, the wheels would only return about halfway back to the straight forward position. So I replaced the servo and it still does the same thing. Any idea what would cause that? Doesn't seem to be anything physically binding, although I could look at that better to be certain. I also added all the lights, so I thought maybe I'm trying to pull too many amps or something, but it does it without the body on, so the only lights left at this point are the rock lights. I could try it without them too, but either way I think I'm going to look into the BEC route you gave me some links to above, thank you again. That would give me more weight up front anyway.
I think the Injora servo I installed came with some different servo saver options, I just used the metal servo (horn?) that came with the TRX. Maybe I should have used what came with the new one...Replace tge servo saver. Kimbrough makes a great one.
Hello, newbie to the RC world here to. What scale of crawler are you wanting to build? I'm seriously looking into the yk 41011. It seems to be a great platform to start with for beginners and it can grow with you.Thanks for the response, lots of great comments and questions; I'm too used to reading facebook posts, they're mostly snide and negative. To be honest, I haven't even thought of searching forums until today.
So what am I wanting to do with it? Not entirely sure where to drive it yet, not much I've found in my vicinity, but the TRX4 seems great for trails, I have a Slash Ultimate, Big Old Losi LST2 Nitro for speed and, well, Hugeness, 1/16 drift car, 1/18 buggy, pretty much have everything covered that I like (oh and a boat and some drones), so I'd like to eventually have a cool crawler. No hurry, probably even leaning more toward building one I guess, but where to start? I don't want to end up with $2,000 into it, or more knowing me, but I want to start with the right platform (chassis I guess) so I'm not wasting money as I go.
