Cordless drill used as starter
knall
saw a couple guys doing this......
What modifications do i need to do ? Got a link to the parts??
The only thing you need is the starter shaft from the original roto start. Clamp it onto the cordless drill and it works like a champ. Just makes sure you don't go to fast and turn down the torque if possible as too much torque may kill the one-way bearing inside. :)
Well I have an EZ start on there now....so i must have to swap something around?
my buddy did this what he did took the ez start off found a socket to fit the one way bearing then super glued it into the socket make sure its in the right way then he just got an extension to hook up to the the drill then your all set
