After completely breaking in the engine. Remove the stock air filter. You will notice that the foam element is completly soaked in air filter oil.
Clean the foam element with WD-40 and remove as much oil from the foam as you can and then paper towel dry it.
Apply a small amount of air filter oil (1-2 drops) and rub it in the foam.
Re-insert the foam element.
It's amazing how much torque I got just from removing excess oil.
Remember you can always re-oil your filter if you don't like the results.
Let me know if it worked for you...
:clap:
:clap:
