Conquistador
HeavyMaxx
I purchased a CONQUISTADOR from ebay and can't seem to get it to pull out of its tracks the motor runs great just wont pull .ANY IDEALS?
Ok I am taking by your post you are using this as a tractor pull MT. Am I right? If so are you using the proper tire set up?
NO not pulling anything with it .THE truck itself will not move when I pull the trigger .motor revs up but no movement.
pulled clutch out seems to be rubbing alittle more on one side its all aluminum...clutches and housing is that normal? or should something else be in there?
How is your flywheel? Is it warped? Check your springs and shoes to make sure they are not warped. Now Check the Clutchbell to see if that is damaged. It should not be rubbing AT ALL when idled.
