clarifying, when you mean side to side, looking straight into the engine from the backplate, it is moving left and right? but it is not moving up and down?
are you sure it is actual slop in the con rod? or is the crank slightly rotating allowing it to move slightly?
i would be very surprised to see side to side slop in the con rod as opposed to vertical play as all the load is vertical. there isnt enough force gained by the weight of the connecting rod to wear in that way unless there was other issues either issue with materials, or something got in there and wore it down.
how much slop are you getting? there is going to be a slight bit of play, as the engine starts it will build up a film from the oil/fuel it
how much slop are you getting? there is going to be a slight bit of play, as the engine starts it will build up a film from the oil/fuel to lubricate.not much the engine was pretty rusty from storage when i got it new maybe it wore the bushing down a bit
