clutch bells
rabbitmadden
how hard is it to change clutch bells on a 3.3 4908 and what else should i check for while i have it torn down. thanks in advance for the help.
its pretty easy all you have to do is pop of the e clip and you should also check for added wear on the clutch
You should also check and replace the roller bearings if they appear stiff to roll or bluued up...I use silicone oil to lube mine and so far its worked out really good at keeping the bearings from frying out as often..
