jon2 said:Have you applied the correct shims?I had the same problem when I first got a Savage. I had new bearings, one washer behind the screw and it never allowed the CB to spin. I knew that was a problem so I got some Ofna shims. Depending on which clutch you use, shims may be necessary to use behind the collet as well to push the CB out further. This is rare.
Let us know what you do.
Jon
NCNitro said:which is actually better? Uber, or Hella?![]()
Timbo said:no i have the engine out
i took the washer off and but the bearings on and now its spining freely
thanks
vbgagnon
kurt_02f150 said:awesome. is it spinning fast enough to create a small (visable) vortex of air around it?
If so, you qualify for uber quick.
