chevelle
well it happened:\ my friend left nitro fuel in his truck for about a week and now it wont start:whhooo: how do you clean out the engine and with what?
WD-40
dfh jkgfujk ghjk tuyi p;,my8lt7yuhbjhsdtrg dras
sorry you do not know what wd-40 is apparently wd-40 is to short an answer for this list hence the extra lettersWD-40
but you could write some more,such where to spray it or how much to spray...sorry you do not know what wd-40 is apparently wd-40 is to short an answer for this list hence the extra letters
don't just say wd40 popofskpokjf
cause that isn't helpful.
:goodpost:
but yes wd40 should help clean out the engine
u could also try putting some fresh fuel in the carb and turn it over... should be enough to burn out the old fuel thats in there
although a week shouldn't matter
After run it's better for that because it oils the engine and it protects it from corrosion.
What brand of fuel?
The proper way to fix your problem is to completely disassemble the engine. Soak all the metal parts in Denatured alcohol overnight, and scrub everything you can off with a toothbrush and rags..
My 1st Revo was given to me by my little brother who lost interest in the truck after 3 tanks. It sat in the Garage in the Florida sun fulll of fuel for a year before I got my hands on it.
A good cleaning with the D.A. and it fired up first pull.
