Chewed up a motor Saver neck
Monteman
RCTalk Racer
Edmonton, Alberta
Had a rub issue with my motor saver neck and my spur gear. Actually cut a small hole in it, good thing i caught it before it started shredding the neck into the carb. :S
Jimmied a fix for it tonight. mounted the motor saver itself to the stock Revo/Slayer air filter neck. Works pretty darn good. The 3 screws that are on the traxxas one tapped right into the base ring on the motor saver, added a bit of CA for good measure. See how it holds up tomorrow i guess. :)
Will watch it closely to see if i need to rig up a mount for the front like the traxxas ones had.
motorsaver is a brand of air filter. the "neck" is the piping that leads from the filter element to the carb opening.
