charging RX pac
Maybe that red light shuts off when it is finished charging. just a guess I am not 100% sure
I dont think the red light shuts off... just like with my glow ignitor chargers... they dont shut off, they stay on as long as it is plugged in.
Ok if you have a 100Mah charger and you have a 1100Mah pack then it will take you approxiamately 11 hours to charge. Figure the current rate for the charger and divide that into your current rating for your pack.
I still recommend a nice peak charger that will do NiMh and NiCd batteries.
Your charger is 120 Mah. Plug it in before you go to work and unplug it when you get home assuming its discharged when you start.
At such a low rate of charge, an hour or two over charge wont hurt. Until you get used to it keep an eye out and make sure it doesn't get to hot close to the end of the charge.
Cool thanks for all the help. I just need to use this charger a few times untill my peak charger gets here.
