Charger's..
Endless
Can someone recommend a good, cheap, quick charger for a 1500mah cell? Thanks.
It's a 7.2v pack. I wanted a quick (as in 15-25 minute charger) charger for cheap. I saw one and it was for $40.
I use a Black Widow pro from Hobby People. It does both NiMH and NiCd and runs on either AC or DC. While probably not the best out there it serves my needs pretty well for charging hump packs and sticks for my starter box.
Thanks, i will be going to my LHS to get a few things after work. Thanks.
Diver6127 said:
Is this for a stick pack or your car's receiver pack?
Stick pack for the EZ Start system. I had problems where the car wouldn't start, then i'd end up using the EZ starter so much that by the time the car stops acting up, i have no more power coming from the pack.
Endless, you can check for Hobbico quick-charger 7.2V. I am using that right now and 30 min charging time. I paid $25 for it from LHS.
Thanks MyJeep.
Endless I have a Cen charger thats used just for 7.2v packs. 25 min charge uses ac/dc. Its nothing special just does the trick, peak charges and sets itself to trickle after full charge. Let me know if your interested.
I need one asap and if i were to get it from you, i would have to send you a money order, which won't get there for another week or so. Lemme look around to see if they have some at the LHS, and if not i will PM you.
