center differential slipping
lenny
I have a ofna mbx. I've took the differential apart and put it back togather and seems to fix the problem for about half a tank all the suden its all done. transfer case seem to be slipping. so i repeat step 1 and start over same problem not shure whats up. any sugestions would help thanks
i went ahead and inspected the gears that seam to be fine. could it be the type of grease. or maybe that i need anouther washer behind the 4 center gears to tighten thing up. i dont have any washers to try this. i will get back when i do
Are the gears worn to the point where they no longer mesh correctly? If so...just replace them. Usually pretty cheap....
