center diff in a 2.5r
2.5 tranny gear are the same all u need is the 3.3 trans case and the center diff and rear brake
If adding the center diff in a 2.5 u will need
trim chassie
3.3 trans case
center diff which come with foc
They sell it at my local Hobbytown USA. and I'm pretty sure that towerhobbies.com should have it in stock by the end of the month!
its that big different between center diff kit or normal trannt gear?thanks
With the center differential set up, it comes with a FOC (forward only conversion) so you will lose reverse along with a lot of the rotational mass in the transmission. I saw in another thread that you wanted to keep your reverse so the center differential will not work for you.
