MaxxRunner
Well I finally got my Maxx up to speed with the Picco .21 upgrade, and I can keep up with the rest of the local pack in the speed catagory, But I cannot get the truck to keep from oversterring in the corners. We run on a small oval track with one table top and a few small whoops on the straight aways. My problem may be from my new found speed but what can I do to tame it down for more control through the corners? If I can get it just right I can make it through with just a little over steer but most of the time there when there is traffic in the turns and I can't get it set up right I go sideways and usually to the infield or the pipes.So my question is this what way should i set my toe in, shock rate caster and camber? I am running Intgey piggyback shocks and RPM arms wide maxx talon wheels with pin spike Panther tires with extra firm foam. Any suggestions ??? :shrug:
