Carb Return
Shady1475
Hey all just wondering if any of you using the OFNA linkage mod are using a carb return spring. Right now I'm having a little trouble with my slide returning all the way. If I hit the brake it will but as soon as I hit the gas again the let off it idles a little high. It's not a real high idle that causes the wheels to turn but enough to notice. I dunno I'm just a stickler for details and it bugs me. Thanks fellas.
Try your idle set screw .. Check throttle servo for center then controller trim etc ,, then play with the idle screw .. Oh yea if you bent the linkage it will perform as you mentioned .. Let me know what ya came up with .. One more thing check the throttle horn as well
