Carange problems
brimoden
Hi people I bought my self a carnage and went on the beach to open it up a bit soon after the back wheels started to free roll can any one tell me what I've done please would me much appreciated. Thanks
I'm not that familiar with that rig. Is that the FTX carnage?
If freewheeling, that points to driveline. Do all 4 wheels freespin? or just front or just rears?EDIT: I just read your post again and see it was just rears. Does that use a rear drive shaft? Again, I'm not familiar with that rig so I don't know what is has for drive system.
Visually check the slipper gear and pinion to see that they haven't shredded one or the others teeth and if teeth are okay, are the 2 gears still aligned and in full mesh? Motor hasn't backed off?
Check slipper first and see if the pads are still okay and the slipper is tight as recommended by FTX. Then check the motor pinion. Its possible that the grub screw holding the pinion backed out.
If you still haven't found the issue, your going to need to start taking things apart and look for potential broken parts. Remove the slipper assembly and look for broken or sheared pins or snapped top shaft.
That's where I'd start, and if noting found, keep digging
Thanks for taking the to reply I am very new to this so if I sound a lil clueless at times please excuse I think its the pin so going to see if its made any difference will repost when I've tried it I not going test it on front street I'm sick of replacing the front end ha ha
---------- Post added at 9:56 AM ---------- Previous post was at 9:52 AM ----------
Sorry yea it is the FTX not bad for starter but breaks very easy my brother got one he's not used his since braking it in due to faults there cheap to repair tho
No worries, everyone starts somewhere. You will get it sorted out. They all break, even the expensive ones. So don't let price worry you. As long as parts are available and cheap, that half the battle.
