MrClean
Sorry, I told you 'how' but forgot the 'why' part. The motor relies on 'pinch' at the top of the sleeve to keep the combustion above the piston and drive it down with the maximum pressure. You'll notice if you rotate your flywheel (with the glow plug out) that there is more resistance (or pinch) as you get towards the top of the sleeve. If you allow the piston to sit at the top of the sleeve after a run, as the engine cools down the piston can prevent the sleeve from retaining it's shape. This can cause premature engine wear and affect the longevity of your motor. I didn't know this in the beginning and I believe my motor has been affected. It still runs like a crazed animal, but I feel it doesn't have the same amount of pinch it did in the beginning. You won't ruin your motor overnight, but keeping the piston at the bottom after every run will definitely prolong the life.
