Rolex said:Is your linkage adjusted properly, and your trim off?
Take off the air cleaner and watch the barrel in the carb as you apply trigger. If you go half trigger before it starts to open, you need to adjust your linkage.
Turn your trim all the way off before adjusting your idle opening.
i dont think that is acurate because i set mine to that and my motor seized. be careful!rctrey said:But in the book it says after break in the hsn will range from 2 1/2 to 3.
