I managed to lose one of my large flanged wheel nuts earlier. Can I use a regular locking nut (as per photo.. It has a much smaller flange)? Or do I risk busting the wheel as the load isn't as spread out? Using 7" Blast/Goliath wheels/tyres..
The serrated ones just help bite the wheel and keep them from coming loose. But as long as the threads the same any will work. Just keep close eye on them from backing off.
Locktite needs to cure for a couple hours. Be sure you're using removeable locktite. Add a dab to the threads, tighten the nut and wait a few hours. Wheel should never come loose on it's own then.
I used the HPI blue thread lock, put a little dab on the bolt, screwed tight & left overnight. Maybe I need to use a bit more or get some oil resistant Loctite thread lock? How do I know it's removable?
