Camber question
JSY0829
Mount Pleasant, Michigan
How do you adjust the camber on the Tmaxx? I did a search and the only thing I could find said there is a hex adjuster on the inside of the hub. Is this correct?
Yes, if you pull the wheel off, you'll see two holes for 5MM wrenches. Now level the arm out and you'll see a 2.5mm hole for adjustment of camber
The 5mm hole sets the slack in the pivot balls so, unless they're excessively loose or tight, don't mess with those.
Now about those 5mm screws...do you tighten them all the way or just snug them up a bit? Just wondering since I had to replace some bulks and didn't know if I would mess with the caster adjustments with them so I left them loose a little.
you wanna just kinda of tighten the 5mm so that you can feel a very tiny amount of play when you wiggle the steering block up and down just enought to alow it to move freely yet not be sloppy...as for the 2.5 alll your gotta do is tighten the top ball for moving it in or loosen the bottom one or the other and it the opposite for adjusting the camber out....
Hey thanks :HI:
I didn't mean to some what hijack the thread...just thought the 5mms screws was for the cmaber adjustments as well as hold things together lol Now I need to find that little screw lol
Ray
