- Aurora, Ohio (Cleveland)
- Racing
Ok, so I just got my little four-stroke dissembled so I can send out my crank to be modded and then have everything cryo-treated. Well, I had been paying pretty close attention to how everything was going together but just as the cam dropped out of it's sleeve in the block I realized that it's pretty darn important to know how that thing was in there relative to the crankshaft. I got the easy part figured out... which end goes in first. But as far as it's rotation, I could use a bit of guidance. It makes sense to me to reinstall it between the exhaust and intake stroke since I'll be able to see quite easily the timing.
So the cam turns one time per every 2 revolutions of the crankshaft. The cams on the camshaft are a little more than 90 degree offset. So for every quarter turn of a cam, the piston either goes up or down completely. I'm theorizing that the exhaust cam should be at peak contact with the pushrod somewhere around when the piston is halfway up.. I can see that there is a small mark on the side of the camgear. I'm sure the factory uses that as a guide when they are assembling them. I suppose it would be best to contact O.S. on this.. Not something I can guess and check. If I guess wrong I'll be buying a brand new valvetrain.. or engine.
