Adam Smith
My buddy has a 4908 Tmaxx. He has run about a gallon of fuel thru it and is very responsible when it comes to after run maint.(piston bdc, afterrun oil, clean air filter etc) anyway. He has been burning up glow plugs in less than a tank of fuel. The car is set a bit to the rich side, not overly rich imo, but just a little smoke under full acceleration. He has been told that running it too lean is the cause but its not lean. He checked the exhaust for restricions and even pulled the cooling head off to check for debris in the motor(he said everything looked ok but he had slight carbon buildup on the piston). He took the motor back to original factory settings and is tuning for just the weather and is still burning them up. He checked his EZ start wand and its A OK. He said the truck jrun great, then just dies after it gets warmed up and won't start, so he pulls the plug, hooks it to the blue wire and grounds it on the head and gets nothing. I am going to try to help him out this weekend with it but not sure where to begin, any ideas??
