Build Your Own Revo 3.3
robmob
THE PEOPLE HAVE SPOKEN!
Community Leader
Napa, CA
I just came across this. "Build your own Revo"
Great way to get buy a new Revo 3.3 using quality after market parts if you are in the market for one.
Just curious what it would total if I did that...close to 1500 bucks
Traxxas REVO 3.3 - Build Your Own!
- 01. Wing Mount (TKR1009) FREE Tekno RC Adjustable Wing Mount (save $25.95)
- 02. Wing (OFN40672W) Jammin Truggy Wing (white, save $1)
- 03. Radio/Servo Boxes (TKR1002) Tekno RC RX/Battery Box and Fuel Tank Conv. (save $5)
- 04. Fuel Tank (MUGE0815) Mugen MBX5-T tank (150cc+, save $2)
- 05. Screw Kit (TKR1010) Tekno RC Essential Aluminum Screw Set (save $4)
- 06. Steering Servo (AIR94361Z) Airtronics High Torque Coreless (save $5)
- 07. Throttle Servo (AIR94360Z) Airtronics High Speed Coreless (save $5)
- 08. Radio Equipment (AIR90270TX75) Airtronics M11 (75Mhz TX/Module only, save $15)
- 09. A-Arms, Front (RPM80212, 80222) RPM Front A-Arms for REVO (black, save $4)
- 10. A-Arms, Rear (TKR1006) 2 x Tekno RC Adj. Wheelbase Rear A-Arms (save $8)
- 11. Turnbuckles (LNS2805) Lunsford Titanium Turnbuckle Kit (save $3)
- 12. Pushrods (JDC10104) JD Carbon Fiber Pushrod Kit (P2, save $2)
- 13. Hinge Pins (JDC10101) JD Carbon Fiber Hingepin Kit (save $1)
- 14. Shocks (TRA5460X) Traxxas REVO GTR Shocks (save $4)
- 17. Pipe (TRA5390) Traxxas REVO Resonator Tuned Pipe (save $3)
- 18. Air Filter (MSFRT60) Motor Saver Air Filter (save $1)
- 19. Clutch (MIP1602) MIP Clutch Kit (save $1)
- 20. Spur Gear (RRP8038) Robinson Steel Spur and Clutchbell (38/15t, save $2)
- 21. Transmission (TRA5394X) Forward Only Conversion (save $1)
- 22. 2-Speed Gears (TRA5383) Traxxas REVO 2-Speed Gear Set (close ratio, save $1)
- 23. Differentials (RRP8090) 2 x Robinson Hardened Steel Diff Gear Set (save $8)
- 26. Wheel Adapters (PRO6034-00) 2 x Pro-Line 23mm Hex adapters (save $3)
- 27. Body (HPI7198) HPI Hellfire Body (save $2)
Big chunk of change when you spend it all at once.
Funny thing is that most of us are perfectly willing to spend that and more if it's spread out here and there.
I believe that's called post kit sticker shock. I know with my Savage I had no intentions of ever spending more than 7-800 bucks on it. One day I decided to total all the money I dumped into it and nearly had a heart attack. The second time around it's not as painful since you truly know what you are getting into.
