broke again
chevyguy80
Okay yall now my 150 dollar sport maxx is starting to get expensive. I have now broke the plastic set of bulkheads that came on the truck. So I replaced them with alluminum one's from Dynamite and now I have managed to bend them. Not only did I do that but a the same time I replaced the front upper and lower a arms with gpm products. And guess what I bent those to. Okay I know what your thinking and no I dont run into a lot of stuff. But I do jump the living poop out of it. Like from 15 ft to probaly at most 25 ft. The question is. Is there a pruduct out there that wont bend or break for the bulkheads. The arms Ill just go back to plastic so it will be cheaper to fix because something is going to break. Oh ya add a set of steering knockles to that list. Thanks for all your help.
I like the plastic bulks so i have something that gives.You may want to get a roll cage that would help.If it is real cold when you run you will break plastic parts much easier-Marc
as for A-arms go get some RMP ones theyre made of some kind of nylon crap and are garunteed not to break or theyll replace hem for free you can pick em up for $9.99 for a Upper & Lower A-amr can't get much better than that as for bulks try getting some more alum ones if you can try and see if you can find any made out of aircraft grade aluminum is stronger or if ou wanna spend some big$$$$ you could go to your local machine shop and hve them make some out of TI cause i dont think any oe makes em outta that
