Bringing a shelf Queen back to life
If you want another way to do the brake tension, use fuel line.
Hi Men, It got worm enough to get out and do some Bashing today. I started out with the HS needle at 4 turns out and slowly started leaning it out. The problem I am having is when you go WOT and let off the truck dies. It will not restart right away and to me it acts like its flooded. I leaned it down to 2 1/2 turns and it still did it. I had a full tank of fuel, the temps at 200-210 and have a trail of smoke. The engine dies if I pinch the fuel line off at idle in 2-3 sec. so I think I have the low speed close. What do you normally have the HS needle set at? As always any help would be greatly appreciated.
Thanks
Mike
