Awesome thanks. Idk why I didnt think about dust cover lol. I am having a issue with that cover not letting the carb close all the way. Any mods or a stronger spring that I can get? If I take the cover off it snaps shut but if its on it doesn't close all the way or closes very slowly.
lol....thats odd ..i know on mine , if i take the return spring off ..the dust cover will open the carb a bit ....but with the spring on i have no issues
and if you put a stronger spring on , you might have to put a stronger throttle/break servo
My mate had the same problem..
All he did was turn the carb a little.. if you have already sealed the engine then i wld suggest a stronger spring.. and if neither work then a new dust cover is cheap enough to expreiment with
Goodluck
Goodluck
I've only eve seen replacment springs on Ebay..
As for stronger ones i have seen different size/strength springs at Bunnings (an aussie hardware store.. i wld if it was me take the spring to a hardware and see what they can do..
Someone else may know where to get one tho..
