I have worked on it so many times, its made me lose a little more hair. Yes I agree wide open throttle is when the throttle is wide open but i have had the linkage unhooked from the servo and pushed the throttle all the way in with the engine runing at full rpms. And yes I have had the air cleaner off otherwise i would not be able to look into the carb and see the slide all the way closed.
I dont understand how I could have the carb on backwards because then the throttle linkage would be on the wrong side. I am not totally dense when it comes to things mechanical, and have had the thing set and idle perfectly at times, and all of a sudden it takes off at full rpms. I am thinking along the lines of an air leak somewhere, thanks for that little bit of encouragement ShakerCo it lets me know that my head may be in the right place on this one. Not discouraged any more I am on a mission, and I really appreciate all of your input. It lets me know I'm not the only one who has ever had problems with these things. lol going to pull the engine again tonight and check for air leaks again the only place i havent sealed is the front end of the engine where the clutch fits on, is there someplace there that should be sealed?????
