Battery ?
CaptNitro
Iowa
Hey guys, i am currently running 2s/25c/6000 mah batteries in my savage flux, is there any advantage to running say a 2s/35c/5050 mah battery instead?? I guess what i was wondering is will I get any more power from a 35c battery vs 25c battery, and will the run times be about the same?? Thanks for the read:)
Hi captnitro. The 35c will give you more punch on the throttle compared to the 25c. Read some more here https://www.rcnitrotalk.com/forum/showthread.php?t=87529&highlight=Understanding+lipo
https://www.rcnitrotalk.com/forum/showthread.php?t=69951&highlight=Understanding+lipo
So basically the higher the C rating is, the harder you are working the motor. If you are after higher C rating, as a precaution, please check your esc if it can still handle the higher C rate, also your lipo charger if it can and will charge the battery of your choice. Be safe.
