Ball cups for turnbuckles?
Rob D
i read somewhere b4 about changing turnbuckles over to a ball cup setup easyer to pop back on then fix a bent one ..
So has anyone does this or have the part#s to do it ? thx
I have not done this modification, but it is a good idea. Here are the parts you might need:
RPM rod ends:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXALN0&P=7
Associated Engineering Ball Studs:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCKU5&P=7
or Trinity Ball Studs:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJV44&P=7
or Duratraxx Ball Studs:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCZJ5&P=7
Someone else might be able to give you more exact information, but the rod ends I listed will fit Lunsford turnbuckles (which means they will most likely fit yours). The three brands of ball studs listed should all work or at least give you a place to start looking when you hit the LHS.
Hope this helps.
Thx sky that should do the trick I've only bent 1 turn buckle but broak a few mounting points on the a arms thats for sure ...just picked up some alum arms and such for it and think I'm gonna build anther maxx :)
Those are the best answer to the turnbuckle question. I run Lunsford Titanium turnbuckles; and since I started running them, I have not bent one nor busted a rod end. Prior to getting them, I was busting rod ends left and right. Something about not landing my jumps quite right :D
