I just want something with more go than the 23cc it's a bit laggy low down. I have seen some already built engines on eBay that are 30.5cc for £180
No it is not. You will have to split the engine case to install the kit but it's no big deal. Everything that Joey said is correct. If I had to buy a kit, I would buy the #2 kit he listed. I used to drag race a motorcycle and performance is what I'm after. If you don't care about the extra performance, then you can get away with the Rovan kit. If you want a motor that runs like a rocket then get the #2 kit. That motor has been ported and stroked and they have adjusted the compression to maintain low end performance. I'm just guessing that it would run like a 35cc engine. (if there is such a thing!) And now you guys got me excited about it because I'm looking for a "secret weapon" to beat my RC mentor that thinks he's the fastest guy around!So that kit is literally a bolt on and away you go hello 30cc? Is it hard to do
