bad savage25
  • Thread starter Thread starter tannera
  • Start date Start date
T
tannera
Guest
i had my savage for a month and I have had to send it to hpi because the back plate,one way bearing,and the disc break were all broken and i had only broke in the engine when i got it back they had tuned it so i tock it out to the park for a test when i was there the the steering went wrong. the next day i take it out agian and the steering work a bit i done a littal jump about half a foothight and it brock the back wheel.
has any one had problems like this.
God no, nothing like that at all. The onyl thing I have broken so far are the rear uprights where the tie rod attaches but that has only happened during really bad landings on asphalt. Last week I was going WOT across a large parking lot and then ramping it off a 2.5' high sand mound, sometimes hitting a tree or a bush but drove it away each time. Must have hit that for a tank and a half before I got bored. I tear mine down after each run and other than the normal scratches, nothing was broken.
I have broken one lower arm and bent one shock shaft. That's all I've been able to break since I got it (Feb.).
My stock motor had a servere case of I don't know WTF!...I couldnt get that motor to act right for anything...neither could the guys at my lhs. I also had a problem with the part of the crankshaft that the one-way bearing sits on...it was striped. Anyway I got a sirio .27 now and I'm waiting on my THS pipe for it and Ill be back out runnin.
