daveovington
Jack of all,Master of none !
- Nanaimo, British Columbia, Canada
- Crawling
- Scale Builder
So I have this rgt rock cruiser body that I think is really cool, and I also have a frame that will fit it but I was thinking of adding some plate steel to all 4 corners with multiple holes drilled and tapped for shock mounting ect.. and then one hanging off each side about an inch lower than the bottom of the frame rail with holes drilled and tapped for links ect... and then.........I was thinking of maybe putting the motor right in the back of it with the 2speed facing forward and the transfer case somewhere in the middle feeding the axles power and because I have enduro axles all I have to do is flip the ring gear over to reverse the direction of the wheels and everything in theory should run like normal. Oh did I mention that the frame will be backwards too because in doing all of this I can drop the height of the truck and I can fit the bigger batteries right between the frame rails length wise with a tray raised a bit above the frame so my axle mounted front servo doesn't hit it when the truck is flexing. Thoughts ???? I know it's a bit mad scientist but like I've said before, " the fabricating and building part of this hobby is what I really love about it "
