jcongerton
Hi
I took my back plate off to give everything a good clean and oil, put back on with cut outs in the right place. Took my car out today, after 3 mins running at temp, the car stopped. Went to start it, and the starter box couldn't turn the engine over, i grabbed the flywheel with a pair of plyers but couldn't budge it. Took the engine out, could see nothing wrong. Loosened the bolts on the back plate, flywheel now spins freely however, there is no way i could leave the backplate bolts that loose they would fall out!! I notice that where the piston is connected to the crankshaft, the crankshaft piston holder is not flush with the conrod. As far as i can see this is causing the rubbing against the back plate, and is now stoping the backplate from sitting flush.
My engine is a Picco P7r, any ideas what may have caused this, best way to repair it, or have it cattle trucked my engine??
Thanks
Thanks
